Adj. Rear Sway Bar Droplinks
Originally Posted by Serge944
I just haven't found a reasonably priced way of going about it. The entire linkage would almost have to be custom machined.
What I would do is use high durometer polyurethane bushings, line everything up with the suspension fully compressed and see if/how much pre-load adjustment you need. You can use something to space the stock link down, like large diameter washers to cover the majority of the bushing surface area.
Cool, I was about to cry when I heard there was a delay. It just wouldn't be right to install my new 951S bar on the stock links
Anyway, I hope everything worked out with UPS (or is it OOPS). It seems like every time I deal with them, something weird happens.
Mine came in today and they look fantastic. Can't wait to crawl under the car and put them on.
Oh....and get my clutch bled so I can actually drive it. That would help too.
