damn bolt
does any one know the size of the drive shaft bolt that holds up the drive shaft pully.? mine fell out on the freeway nd droped the pully and messed up all my belts. luckly the timming belt stayed in. thanks
-saul
-saul
Hey Man
Actually the crank bolt is an M16-1.5 x 60mm but takes a 24mm socket. Don't forget that special washer behind the pulley...no washer, no oil pressure. Sorry to hear this, I hope your oil pressure held up when you lost that bolt.
Get a deep socket 24mm or you may blow up an extension working with that thing, I know I did removing it when I did my belts. Surprised my ratched survived!
Be sure to torque that thing good...
what kind of special washer do i need.? Is it rubber or metal.? Yeah the pressure held up but once i noticed a drop i pulled over and turned the car off, thats when i really knew something was horribly wrong. By any chance does any one know the torque spec for it.?
I got the bolt and washer i needed now im just waiting for them to arrive along with my belts. By the way i am going to change all the belts.. any advise on how to do it.?
