Shift Knob Question
Shift **** Question
Hey guys I have a shift **** that was made for a M10xP1.5 shifter thread and I was wondering if anyone knew of a short shifter or shifter adaptor that would allow me to use that ****. Thanks in advance for any help.
If you know the brand try searching their web site for an adapter. The 944 shifter rod doesn't have any threads at all (it's not even round). A clip is all that holds the shift ****/boot assembly on. Otherwise you may need to find a welder who can modify the shift rod.
I have an aftermarket non Porsche shifter on my car. They come withe plastic inserts to make them fit multiple vehicles. Not Porsche though, they are all round/threaded. I carved a insert right down the middle but not all the way through, then the straight bar fit easily into the groove I cut. It doesnt wiggle or twist but I can pop it right on and off because its not set into place. Try and get some pics up this weekend if you want.
I bought a momo adapter from performanc products. here is the link http://www.automotion.com/productpag...ign=PP_Froogle . It is listed as a 928 shift **** adapter. It looks like a tuning fork. It slips over the shift lever and viola, you have a round shift lever. It is only about $15..... plus something like $10 shipping.
When i had the shift lever replaced I had the shop circumsize it. The chopped a few inches off the top. with the adapter and a advance auto solid aluminum **** that has a male outside thread that fits a momo shift boot I have a very nice setup, that I can recommend.
also, i put some heavy tape on the shift lever before i put the adaptor on. It dampened some of the vibrations.
