Hatch Glass Separation
The frame seals against the body. Unless your hatch seal is in really bad shape, the only way water will get in is between the frame and the glass when the bond fails. If the trim is pulled forward like in the first pick, that probably means the frame has come unglued and it is starting to bend.
