cant remove o2 sensor
Old 06-07-2007, 12:29 AM
hpservertech
hpservertech's Avatar
I had the exact same problem. Shop couldn't get it off with torch or freezing it. they just cut a new hole in and a new mount. total cost was under $50.
Old 06-07-2007, 09:40 AM
PorscheDoc
PorscheDoc's Avatar
Originally Posted by SD Porsche Fan
Fixed it for you Doc!
Haha, you know I couldn't officially say that!
I do keep a tool in my box named "Thor"
Old 06-07-2007, 12:06 PM
Jfrahm
Jfrahm's Avatar
What I have done is put the car on ramps with the exhaust fully hot, cut the wire and use a box wrench. Keep pressure on the wrench and hammer on the wrench at the far end.
Old 06-07-2007, 02:19 PM
mpd425
mpd425's Avatar
I took mine down to the local muffler shop and they torched it to get it out then put the new one I had in and only charged me $15.
Old 06-07-2007, 08:35 PM
Komradekozik
Komradekozik's Avatar
counterclockwise?
Komradekozik
see its not running right when it gets hot so i can take it anywhere but my home,
Old 06-07-2007, 09:08 PM
Calmchaos
Calmchaos's Avatar
I sprayed mine with blaster and tried heat.
Used a 1 foot wrench... didnt work.
2 foot wrench with heat.... nope.
put 5 foot PVC pipe on the wrench, crouched sideways on the ground, put my feet on the front wheel and the pipe on my shoulder. Then I just stretched out until I heard a pop...
Broke my wrench...
Got a new sensor... and a new exhaust from the headers to the muffler....
needed a new cat anyway...
LOL.
Old 06-07-2007, 09:53 PM
Andy1212
Andy1212's Avatar
Broke my wrench...
Hah sounds like me trying to get that damn cam shaft bolt off. The engine was starting to twist off its resting place so i never got that bolt off.
Old 06-07-2007, 10:48 PM
frexe
frexe's Avatar
Gotta invest in some good tools! Or get the craftsman from sears they have lifetime warranty I believe. Anyways I was just under taking the starter out to rebuild, and yeah that o2sensor is positioned ontop of the exhaust, i used a vice grip and a long crescent wrench as leverage and got it off. Note: keep an eye on ur o2sensor wire, secure it up higher i guess the po changed the o2sensor.. and yeah.. the connection was severed, melted in half. Good news is I dont need a new sensor.
Quick Reply: cant remove o2 sensor
