Hit 200,000 miles yesterday
#32
Just a car guy
Originally Posted by GOBOGIE
200,000??? I saw your car at Fest '05 and it looked like it had 300,000 then?!?
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
So are you bringing that bald head to Fest 07? I really missed doing the Benny Hill slap last year.
#33
Just a car guy
Originally Posted by Mikerex
278K here, original motor, only rod bearings have been done. I hope to get 350K before a rebuild
So we've got a bunch in the 220-250K range and a couple in the 350K area. Hope I can keep the rust away from the (critical) body structure of mine for that long. I'm pretty sure I can keep it mechanically sound (hell - I've been doing that for the last 7 years now...)
![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
#34
Canadian Yankee
I have almost 175,000 miles on mine. Did headgasket last year. For preventivie maintence. It looked like it ws going to go so I changed it. W/P and belts needed cahnging to so I did those either than that. all original, will need a head rebuild here in the next 10,000 or so. And the best part. Dash has NO cracks in it, and the car looks like a 75,000 miler
Brandon J
Brandon J
#36
Congrats Scott!
You have about 100K on me, and at this rate I'll finally catch you......................um, that would be "never"
I was thinking of changing out the original rubber-centered clutch disc as preventative maintenance, but I might be 150K shy of that mark after all
Brian
Brian
#37
ive heard of someone w/ 90k on the original belt- but thats just scary.
anyone know how to prevent dash cracks? I had one when i bought the car and now theres another forming, i need to do something to stop them! And no dash covers....
#38
While my '44 has 143k on it, my '79 280zx has 265,000 on the original internals and top end. The only thing ever done to the motor was adjusting the valves and the occasional valve cover gasket. It burns no oil and runs good compression numbers within 2-4% across the board.
I know, I know...it's NOT a Porsche, but I had to add my little tidbit too...
#39
Almost Addicted
I bought my most recent (3rd) 944 with a broken odo at 257,000 for $1900. At some point I guess I'll get that fixed. That was over a year ago, I know I put at least 30-40k on it last year. Still runs really strong. I was planning to just use the body (just has some dings, but needs new paint) but for some reason it keeps going, so I'm actually considering just going ahead with a front seal/timing & balance shaft belt/water pump job. At this rate I'll end up killing it with a broken belt before it gives up the ghost on its own. Pretty amazing.
#43
Budding Photographer
Originally Posted by Scott at Team Harco
So are you bringing that bald head to Fest 07? I really missed doing the Benny Hill slap last year. ![Cheers](https://rennlist.com/forums/images/smilies/beerchug.gif)
To answer your question - no I'm not going to make it to the Fest this year... I'm currently working/traveling out West and residing on the SW coast of Oregon!
#45
Chainsaw
![](https://rennlist.com/forums/images/ranks/veteran_navy.png)
200,000 miles on 12.26.06. She is now at 208k+ and had a broken speedo when I bought the car.
As an aside, the P-car is not my DD, and still I've put 8,000 miles on her in less than six months. These weekend trips do add up.
