so where does the o2 go?
Not Special
You mean the O2 sensor?
It's under the car, sticking out the top of the exhaust pipe just before the cat (if you have one). Best way is to jack up the car, heat up the sensor (run the car until exhaust is hot or use a torch if you have one), then wrench it off.
