250 lbs. Weltmeister springs. Will 215/60/R15 tires rub with these on?
Official Bay Area Patriot
Fuse 24 Assassin
Fuse 24 Assassin
I was looking at clearances on my car and taking some measurements. The car looks low already with 220lb. H&R springs. I am wondering if 250 lb. Welmeisters would rub with my factory tire size. Any thoughts?
Fuse 24 Assassin
Fuse 24 Assassin
Very true. I'm also going to have the car realigned and the camber set at -1.5 degrees. Perhaps that will help the sidewalls clear a little bit better too.
I was running 225/50/15 and then 235/45/16's on my early car with the 250# welts. No issues. You may need to dial in a bit of camber, but nothing too excessive - I was running around 1.5 - 2 degrees.
I've got the 250lbs springs on my 944 -82, running 225-45-17, theres no way it can rub cause the car is as high as it was with the original springs (30mm lower my ***).
So I'm rebuilding to coil-overs in the front.
