turbo trans in NA
turbo trans in NA
Is it a plug and play swap? someone on pelican may want to buy my turbo trans to put into an NA. Can someone please inform me what is needed.. if anything.. to fit the turbo trans into the NA. Also, are the gear ratios the same?
any info would be greatly appreciated.
thanks,
keith
thanks,
keith
Depending on the year of the NA it can be plug and play, but the much longer final drive in the 951 unit will destroy any last bits of NA performance. It is really a bad idea. Even the S2 gearbox in a 2.5L NA will hurt performance although by not as much.
Gear ratios are higher and I don't believe its bad for the n/a especially if you want a stronger tranny that will last as long as the engine and better gas mileage. If you are building a track car, you wouldn't want to do it. It will bolt directly into your n/a and if you are putting it in an early all you have to do is remove the early mounts and bolt it on the turbo tranny. I had a turbo tranny in my 85.5 n/a because they are stronger and I got better mileage without noticeable difference in acceleration on the streets. I felt a much bigger difference going from 15" wheels to 17". I am willing to bet if someone drove my n/a with the normal tranny versus my n/a with a turbo tranny, they won't know the difference if I didn't tell them.
For anyone who is going to comment on the feel/difference in gear ratio and power, make sure you HAVE DRIVEN a n/a with a turbo tranny first and not pass misinformation.
Michael, ask Nurnur as he had one years ago with a turbo tranny and didn't know it. Come down if you have time as I am doing major cleaning after spending $2500 in concreting the whole front yard so I have space to park my 25ft minibus and 24ft enclosed trailer.
FWIW, Genikz and I just popped in a 944S transaxle (same as Turbo box except for final drive and 5th gear) in my early and it fits and works like a charm. Like Lego says, just swap the tranny mounts.
