Shp just changed the oil..it smoked on startup
Canadian Yankee
As the title says, I had the dealership where I work change the oil bcause i though that is something they couldn't screw up. well on intial startup it started really rough first off. Secondly it smoked on startup and then slightly afterwards going on down the road. It doesn't appear to be smoking now, I will be leaving here in a few mins to grab a bite to eat and I will check then to see if it smokes again.
Oil level is fine, Oil filter is on tight. I just can't firgure out what caused it to smoke
Brandon J
Brandon J
Smoking from the exhaust or under the hood? Could have spilled some when pouring into the fill tube (i do it all the time) or it could be burning off from when the oil filter was removed (unlikely).
Canadian Yankee
It came out the exhaust. It looked like a 911 starting uo and nice white with a tint of blue smoke out the back
Brandon J
Brandon J
Canadian Yankee
I normally do it. but since I work 6 sometimes 7 days a week now and theyy are 1 hour days i don't have time to do it.
brandon J
brandon J
