Temperature off the scale
My temp gauge is reading off the scale (hot) most of the time. When its not, it reads normal. The engine appears to be running at normal temp so I guess its the gauge (tried a new sender unit which didn't fix it).
Can I fix this myself or does it need to be sent off for some boffins to fix?
thanks chaps.
oh my poor head
thanks chaps.
![cherrsagai](https://rennlist.com/forums/graemlins/drink.gif)
You might also have an air bubble in the cooling system. When you take any of it apart it is important to bleed the air out of it. There is a bleed port at the front of the engine (takes a 12mm wrench). Do a seach to find many threads on this topic.
Toronto eh. I have a remote infrared sensor to read temp so why not drop by the GTA get together on Saturday and I could take a reading ( go to all forums and click on Canada). You really don't want to be running off the scale though. If the temp reads normal some times and at other time hot it could be anumber of things. Do both fans come on when it gets hot?
Originally Posted by fpena944
Check your grounds. I had the same problem too but it was intermittent.
Chainsaw
![](https://rennlist.com/forums/images/ranks/veteran_navy.png)
If you need to cool the water down, try turning on the air conditioner. Turning on the A/C activates the fans which pulls more air through the radiator. My '86 944 runs close to the top, in the summer and at high revs (autocrossing). I turn the A/C on and the temp returns to normal, or at least close to normal.
Given that you live in Toronto, you prolly don't have this problem, but running water wetter helps lower all-around temps; I'll be throwing some in my rad in a bit. Then again, I live in Tucson...
Originally Posted by Lemming
If you tap the plastic in front of the guage when it's pegged, will it return to normal?
Originally Posted by ausgeflippt951
This is actually not very plausible, given the respective thermal conductivities of both water and air. If there were an air bubble, you'd be seeing a lower temp than actual.
I could hit the top of the dash and it would at times return to normal. Do you think it might be something else?
I don't believe that you have anything wrong with your cooling system, instead you likely have bad connections at the guage end. Pull you cluster and check for good connections and clean you grounds. I am currently having the exact same problem with my 986 daily driver; but I'm too lazy to fix it.
