S2 Exhaust?
Does anyone know if other (turbo, NA) exhausts (cat back) are the same as for the S2? I have a 90 S2 and I was told that the exhaust from 86-91 should be the same and want to confirm.
The 3-bolt flange where the catback bolts is larger on the S2 than other years. The catback section on the S2 also has a traingular shaped resonator right at the flange. turbo will definately not fit as it has a 4-bolt flange.
