Clutch shudder when down gearing
Originally Posted by Airflite40
Why would you do that? Why not just take it out of gear (N) and slow the car down by using the brakes when approaching a stop light?
Sorry if I sound stupid, like I said, I'm new to the whole 5spd thing....
Originally Posted by Lumbergs Lackey....MmmmKay
Dude, don't forget to blip the throttle to bring the revs up before you do that. shudder = gone when you do that.
Uneven flywheel surface can give you shudder when engaging/disengaging the clutch. Is it worse just after you've driven the car hard or slipped the clutch too much under throttle?
Originally Posted by JohanvdWalt
I only go down to 2'nd and select 1'st after I came to a full stop.
And yes, it is always good to be in-gear for evasive purposes. It's ESPECIALLY important when riding a motorcycle. Drivers just don't see you and I've had a few instances of being stopped at a light and someone tries to move over into my lane while on my bike. They would have swiped me, were it not for me being able to get the hell outta there.
Airflite, it sounds like you've never autocrossed before. I definitely recommend it, as it teaches you the TRUE quirks of any car, as well as gets you more accustomed to up -- but mostly down -- shifting quickly and under heavy-load situations. It's also outrageous fun.
Also, on the street you should heel-toe as often as you can (where appropriate, of course). It's not just a maneuver that is handy in race-situations. I've certainly been thankful of my habitual heel-toeing when faced in evasive-maneuver situations.
I match rpms when downshifting and always compression brake... do it in the 944 and my motorcycle.
Just a bike habit really, I like to be in or near the powerband in case I need to get back on the gas.
Neither will shudder, why is this bad?
I understand that heel & toe will help but it should not be necessary in all my other cars I have never had this problem.
Something is wrong with my '44 and I want to find out what it is.
