Engine lift ring mount points with no cam housing
Herr Unmöglich
The motor in the parts car is stripped down to just the block and bottom end now... I want to pull it out of the car this weekend. I can easily rebolt the front lift ring to the alternator mount point, but where can I bolt up a lift ring on the rear of the engine?
I have used a spare lifting ring attached to one of the bell housing bolts in that same general area. Was going out the bottom though and onto a transmission jack.
Eric, when I pulled the block from up top, I just put one of the bellhousing mounting bolts in and used that.. using a bracket might be even better.
Darren, putting the cam housing back on would mean putting the head back on too
Not Special
Darren, putting the cam housing back on would mean putting the head back on too![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
![cherrsagai](https://rennlist.com/forums/graemlins/drink.gif)
Herr Unmöglich
Yeah, Darren has a free pass on this one. Besides, he needs the random tools I have collected when we do his cam housing gasket next month...
and I have been a good caretaker for those Guiness you left behind.... they didn't last too long. It's easy to consume two beers when removing exhaust and a busted old head.
Herr Unmöglich
That will likely work fine... I'll be dropping the motor down to the ground and lifting the car over it. No reason to pull the old junky radiator and 3 blade fan... that crap is going to the bone yard with the chassis.
