ArnnWorx Throttle Body Reseal Kit
![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
My throttle body is soaking in cleaner over the weekend and I'll be ready to install the new seals on Tuesday!
It's something everyone should do if you haven't recently. Most of the seals crumbled while I was prying them out!
Defending the Border
Rest In Peace
Rest In Peace
Highly recommended!!! My shaft orings were cracked and super brittle, it's an easy job to help make sure your A/F ratio is correct.
I am getting ready to do my third one. On at least one car the oring on the idle air screw was so brittle and hard that the engine vibrations were changing the adjustment on it.
To bring this back from the dead, quick question, the instructions say that there are 2 o-rings on the TPS sensor side, and 1 on the return spring side, but it seems these are backwards? are the instructions mislabeled? Also does anyone have any pics on how that spring is orientated? The pictures in the instructions aren't that clear on it, and I'm an idiot for not really looking at it before i ripped it out. Also this is for a 951.
Thanks.
Thanks.
bumping this ancient thread. Anyone know if one of the three kits will work on an S2?
EDIT: Just got a reply from Jason@Paragon, guess it does not work with the S2 throttle body
