951 brakes
951 brakes
I know this is a stupid question but... I have an early car i know i will need calipers, rotors and spindles from an 86 951. My main question is can i fit 951 brakes in my 15 inch wheels?
Official Bay Area Patriot
Fuse 24 Assassin
Fuse 24 Assassin
If they are 15" early offset phone dials yes you can. I have the 951 brakes on my 1986 NA. They fit under there no problem. Be advised that you are going to have to elongate the upper strut hole (the oval hole) 3mm in order to accommodate the new spindles since the holes to mount them on are 3mm higher. Get a dremel and a grinding stone and you should be set.
