944 Rear Coil-over's
Since Leda has gone out of biz(they may come back), any suggestions for a good replacement for rear coil-over conv? My current setup is Koni's sports upfront with 450lb springs and was shooting for rear Leda's with 150lb, for a stiff street and good DE setup. I would like the outlay to a minimum, <$1200. The Leda's were about $1000. Since the rear torsion bar needs to re-indexed what's the cons on just going with a stiffer bar?
get the koni coilovers from paragon- rear torsions work fine larger but are not as easily adjustable when you want to corner balance or just adjust your ride height.
And the rear Koni shocks have to be removed to adjust them and they are single action. TB isn't a bad option, need a 30mm or 31mm TB to match your front spring rate so you will be at the upper limit of what is available off-the shelf.
Has anyone looked at Bilstein. There's isn't adjustable but you can get the rears as coil overs.
