cam tensioner project
Old 03-23-2007, 10:57 AM
harrisonrick
Captain Obvious
harrisonrick's Avatar
Default cam tensioner project
Thought I'd post pics of last nights project. Very easy to do, don't be afraid to attempt yourself!
Old 03-23-2007, 11:12 AM
jgporsche
jgporsche's Avatar
good job!
Old 03-23-2007, 11:43 AM
potent951turbo
iPod Tamer
potent951turbo's Avatar
Good pics!
Old 03-23-2007, 01:26 PM
500's Avatar
Nice! Very clean motor inside BTW.
Old 03-23-2007, 01:56 PM
harrisonrick
Captain Obvious
My thought was it was clean too...the cam lobes look like new with no wear. the chain has no play in it and looks like it could last indefinitely.
I am working on the cam cover refinishing this weekend...will post.
Old 03-23-2007, 01:59 PM
JayP
JayP's Avatar
That's my next project. These pics helped out alot- the write up (either clarks or linked from it) didn't describe the back side very well.
Old 03-23-2007, 02:30 PM
harrisonrick
Captain Obvious
The tensioner was a breeze...just depress it on the pad and manouvre it out. Installation is the opposite. Some wiggling, but it was simple.
Old 03-23-2007, 02:47 PM
JayP
JayP's Avatar
What parts did you replace? Is the tensioner 2 pieces?
I may stop off at Zims and get the kit.
Old 03-23-2007, 11:34 PM
harrisonrick
Captain Obvious
The j-tube comes out, then you can take the tensioner off...it's one piece. The pad on the top slides off and the bottom one has 2 screws. You get new screws from Zims with the set...$150 USD plus shipping. It sucked for me in Canada, since customs grabbed some $, + GST, total was $220 CDN....since I have low kms...125,000 kms, I'l leave the tensioner until next time around, then I'll replace it too. Likely that will happen with a belt change and waterpump change.
Old 03-24-2007, 12:19 AM
JayP
JayP's Avatar
My old house in Bedford was walking distance away from Zims... but no 944 then. Now I'm a full 5 miles away.
Thanks for the info. It's making it easier to maintain this lump!
Old 03-24-2007, 12:00 PM
Jay W
Jay W's Avatar
I think its nuts that they charge $35 for just the top pad, but the top and bottom pad kit is $150. I wonder what the justification is for basically charging $115 for the second pad and screws. My car really needs the bottom pad but I bought it before the kit was available.
Old 03-24-2007, 03:34 PM
eohrnberger
eohrnberger's Avatar
Been looking for a bottom pad. Are you telling us that there is a place where we can get just the bottom pad? I'd be up for that.
Old 03-24-2007, 07:09 PM
harrisonrick
Captain Obvious
If my car had over 100,000 miles, I would have bought the whole tensioner with new pads from Ian at 994online...its @ $350 or so IIRC.
When I looked at the pads fresh out of the plastic bag...I thought...damn I was ripped off. The old pads were yellowed (from oil I assume and age) and seemed ok. I've read posts were guys took the pad off and it cracked into 2 pieces on removal...so...
Better safe than sorry I suppose.
The alternative makes the hair on my neck stand up...
Old 03-24-2007, 07:21 PM
V2Rocket
Rainman
V2Rocket's Avatar
You mean the unpleasant sound of your chain whipping in its slack, the grinding of plastic against camlobes and the sudden knocking sound of your pistons hitting your stuck-open valves?
I'd say $150 is well-worth it.
Old 03-24-2007, 09:52 PM
eohrnberger
Exactly the point.
Looking for the bottom pad. Top pad was already replaced. The tensioner moved freely and was in good shape.
Just need the bottom pad, and it really didn't look bad when I had the entire thing out, while the top one had a crack 1/4 of the way through, or so it looked.
Quick Reply: cam tensioner project
