which brake lines?
which brake lines?
so i'm browsing paragon and they have two types of braided brake lines
Note: Check your front factory brake lines to see if they screw directly into the caliper or if the flexible line attaches to a hard line that then attaches to the caliper. POR500 lines are set up to screw directly into the caliper and POR550 are set up to attach to a hard line coming out of the caliper. Choose the right set for your car.
does anyone have any visual representation of this?
mine is a 1983 with no ABS, i looked at this morning before work, and its just a rubber piece, that ends in a metal piece that has the provision on it for a wrench, and then the caliper
i guess thats the "without hard line front" type?
