sparking!?!?
I don't know why it would be sparking, but if you want to prevent the problem you can reach under the seat and disconnect the wiring harness. Sparking sounds like something to the effect of the wires crossing?
I'd highly recomend you pull the entire seat out to see what issues may be lurking in the wiring. It should be held in with either 4 or 6 allen head bolts, and after you get those out the seat just pulls out.
