Knocking sound
Knocking sound
I hear a knock or rattle when I accelerate with the car in gear. The knock sounds like it comes from behind me in the area of the exhaust or transmission. It's a rattle-like sound as if the door is ajar. The knock sounds in time with the engine RPMs, it speeds up as I accelerate. I only hearit with the car in gear, I don't hear it if I hit the gas in nuetral or with the clutch in. I don't think the muffler is loose.
Is it possible that something is wrong with the exhaust system or transmission?
Thanks in advance.
Thanks in advance.
Ditto
Drivers CV Joint.
Mine was banging on the right so I replaced both. You could see the discoloration of the burned bearing in the outer joint on the right side. Made a clicking sound also (at low speeds) as well documented on the net.
I've got an axle with 2 good joints on it if you want it for $50 plus shipping. LMK.
Drivers CV Joint.
