Brake pads - occasional track use?
I'm trying to find a decent set of brake pads for my dad's '88 944 NA. I was thinking KFP Magnum Gold, or Porterfield R4S. The car will be mostly street, with an occasional DE/AutoX. This will be his first year with any sort of track event, so I don't expect him to overheat the brakes too much.
Do any of the above pads squeal bad on the street? I have Performance Friction PF97 on my 911. They're a fantastic track pad, and bite real good on the street too, but I need to swap them out because the squeal is annoying.
Thanks!
Thanks!
I suggest the Pagid Sport pad, dark blue, don't confuse them with Pagid Blues. I believe the designation is RS 4-2-1.
I use them on my daily driver ('02 996 C4S) and occasional track days.
i used to buy metal masters from paragon for my n/a - worked great on the street, saved the rotors from wearing quickly, and on a two day DE i would about half kill them but still have brakes the whole time.
I am using the R4S right now with the 951 Brembo's. Great dual use auto-x and street pad. Have not been able to overheat them yet. Very little dust and no noise at all. I like them alot, but for the sake of experimentation i am going to use the KFP Magnum Gold next.
I dont think you will find Pagid pads available for the 944 n/a single piston floating calipers (at least they were not avaible a few years ago).
I believe the KFPs are a carbon kevlar compound (the old Cool Carbon brand name) and Porterfield R4S pads (also a carbon based pad) will squeal. Possibly more than your liking for a street car.
But keep in mind that new/novice drivers can be very hard on brakes (the cars often have stock/soft suspension, street tires, and new drivers tend to slow down too much for corners). So they are more likely to overheat brakes than an experienced driver in a well setup car.
Nothing destroys your on track confidence more than weak brakes. Go with a good track compound pad (Hawk Blues, Porterfields, PF97s, etc), and if they sqeal too much for street use - swap them out after the event.
For the occasional track / mostly street use, the KFP Golds should suit you fine. Yeah, they do squeel like a greased pig in a butcher's shop, but I suppose that's a small cost for fine stopping power...
-Z
-Z
Id get some OEM pads and swap track pads for events. It takes like 20 minutes to swap pads, and can be done on site at the event. Ive been very happy with PFC 97s in my 924S. They can be squeaky when they are cold, but they sure have good bite. They are a little squeaky but since I pretty much drive my car to the track what do I care, LOL.
$99 shipped if anyone wants some.
I've got Hawk Blues on my ITA car and they work awesome even though I have rotors smaller than 10" in diameter and stock single piston brake calipers. I'm only stopping about 2,200lbs though.
I am using PBR performance plus on front, and whatever was on rear when I bought the car. Eventually, I will replace rotors, bearing, and pads, but PBR's came highly recommended for "spirited driving"
Bleed the system with a MityVac and replaced with Castrol.
Originally Posted by The DareDevil
I have some new Pagid (OEM) pads for the n/a.
Pagid sport or race compound pads are not made for the Girling single piston floating calipers.
Porsche 356 C 63 - 65 4304 4122 T0475
911 72 - 83 4501 4304 T0475 T0449
911 S 72 - 83 4503 4304 T0475 T0449
911 2.7 / 3.0 / 3.2 Carrera 73 - 89 4501 4304 T0475 T0449
911 3.3 SC Turbo & T. S 77 - 90 1203 1203 T0377 T0377
911 wider race caliper 1916 1916
928 S 80 - 85 1144 4623 T0413
928 S & S4 & GT 85 - 95 1204 1203 T1074 T0377
928 5.4 GTS 32V 91 - 95 1842 1203 T5103 T0377
935 Moby Dick ers371
944 2.5 Turbo 85 - 87 1203 1203 T0377 T0377
944 2.5 Turbo 87 - 91 1204 1203 T1074 T0377
944 2.7 & 3.0 S2 88 - 91 1203 1203 T0377 T0377
959 2.8 87 - 91 1842 1842 T5103 T5103
964 C2 3.6 88 - 91 1203 1580 T0377 T1157
964 C2 3.6 91 - 94 1203 1203 T0377 T0377
964 3.6 Carrera RS 91 - 93 1204 1203 T1074 T0377
964 3.6 C4 88 - 94 1203 1203 T0377 T0377
964 3.3 Turbo & Turbo S 88 - 91 1204 1203 T1074 T0377
964 3.3/3.6 Turbo/Turbo S 91 - 93 1842 1203 T5103 T0377
968 3.0 Coupe 91 - 95 1203 1203 T0377 T0377
968 3.0 Coupe Sport 91 - 95 1204 1203 T1074 T0377
968 3.0 Coupe Turbo S 93 - 95 1842 1203 T5103 T0377
993 3.6 Carrera & C4 93 - 97 1204 1203 T1074 T0377
993 3.8 Carrera & C4 95 - 97 1204 1203 T1074 T0377
993 3.6 Turbo & Turbo GT2 95 - 97 1842 1204 T5103 T1074
993 3.8 Carrera RS & RSR 95 - 97 1842 1204 T5103 T1074
993 GT2 & RSR (380 disc) 95 - 97 1908 1204 T5103 T1074
996 3.4C & 3.6 97 - 05 2405 2406 T5104 T5105
996 C4 S 01 - 05 2474 2405 T5110 T5104
996 3.4C Super-Cup 97 - 98 1842 2405 T5103 T5104
996 3.4C Super-Cup 99 - 01 2474 2405 T5110 T5104
996 GT3 R & GT3 RS 00 - 05 1908 1674
996 GT3 & 996 Turbo 99 - 01 2474 2405 T5110 T5104
996 Turbo 02 - 05 2474 2405 T5110 T5104
996 GT3 02 - 05 2707 2405 2707RS421 T5104
996 GT3 Super-Cup 02 - 05 2707 2405 2707RS421 T5104
996 GT2 02 - 05 2707 2405 2707RS421 T5104
997 05 - 2405 2406 T5104 T5105
997 S 05 - 2474 2405 T5110 T5104
997 Turbo 06 - 2707 8006
997 GT3 06 - 2707 8006
997 GT3 CUP 05 - 8004 8006
997 GT3 Cup Grand Am Spec. 07 - 8038 8037
997 GT3 RSR 07 - 2488 1674
Boxster [986] 96 - 05 2407 2406 T5106 T5105
Boxster S [986] 99 - 05 2405 2406 T5104 T5105
Boxster [987] 05 - 2407 2406 T5106 T5105
Boxster S [987] 05 - 2405 2406 T5104 T5105
Carrera GT 04 - 2707 2707 2707RS421 2707RS421
Cayenne Turbo (18" wheels) 02 - 2845 2406 t5105
Cayman S 06 - 2405 2406 t5104 t5105
