Brake pads - occasional track use?
I have KFP Gold front and rear with new rotors and they SQUEAL really bad! On the track, they are great. If I had to do it all again, I would probably go with Hawk Blue as my friends car doesn't squeal anything like mine.
For occassional track use, I would recommend Hawk HP Plus.
Herr Unmöglich
I'm running the HP Plus and as I commented earlier, they do tend to be dusty, and they do like a little bit of heat for best use... but they are nowhere near as harsh on rotors when cold as Blues...
It's really the dust that makes them squeak on the street, but so far after a couple track days they have been great for that purpose.
![](http://derek.bp6.com/porsche/parts/pagid_oem.jpg)
No, not the Textars.
Originally Posted by Oddjob
If you are referring to Textar pads (as OE), those are not suituable for track use.
Pagid sport or race compound pads are not made for the Girling single piston floating calipers.
Porsche 356 C 63 - 65 4304 4122 T0475
911 72 - 83 4501 4304 T0475 T0449
911 S 72 - 83 4503 4304 T0475 T0449
911 2.7 / 3.0 / 3.2 Carrera 73 - 89 4501 4304 T0475 T0449
911 3.3 SC Turbo & T. S 77 - 90 1203 1203 T0377 T0377
911 wider race caliper 1916 1916
928 S 80 - 85 1144 4623 T0413
928 S & S4 & GT 85 - 95 1204 1203 T1074 T0377
928 5.4 GTS 32V 91 - 95 1842 1203 T5103 T0377
935 Moby Dick ers371
944 2.5 Turbo 85 - 87 1203 1203 T0377 T0377
944 2.5 Turbo 87 - 91 1204 1203 T1074 T0377
944 2.7 & 3.0 S2 88 - 91 1203 1203 T0377 T0377
959 2.8 87 - 91 1842 1842 T5103 T5103
964 C2 3.6 88 - 91 1203 1580 T0377 T1157
964 C2 3.6 91 - 94 1203 1203 T0377 T0377
964 3.6 Carrera RS 91 - 93 1204 1203 T1074 T0377
964 3.6 C4 88 - 94 1203 1203 T0377 T0377
964 3.3 Turbo & Turbo S 88 - 91 1204 1203 T1074 T0377
964 3.3/3.6 Turbo/Turbo S 91 - 93 1842 1203 T5103 T0377
968 3.0 Coupe 91 - 95 1203 1203 T0377 T0377
968 3.0 Coupe Sport 91 - 95 1204 1203 T1074 T0377
968 3.0 Coupe Turbo S 93 - 95 1842 1203 T5103 T0377
993 3.6 Carrera & C4 93 - 97 1204 1203 T1074 T0377
993 3.8 Carrera & C4 95 - 97 1204 1203 T1074 T0377
993 3.6 Turbo & Turbo GT2 95 - 97 1842 1204 T5103 T1074
993 3.8 Carrera RS & RSR 95 - 97 1842 1204 T5103 T1074
993 GT2 & RSR (380 disc) 95 - 97 1908 1204 T5103 T1074
996 3.4C & 3.6 97 - 05 2405 2406 T5104 T5105
996 C4 S 01 - 05 2474 2405 T5110 T5104
996 3.4C Super-Cup 97 - 98 1842 2405 T5103 T5104
996 3.4C Super-Cup 99 - 01 2474 2405 T5110 T5104
996 GT3 R & GT3 RS 00 - 05 1908 1674
996 GT3 & 996 Turbo 99 - 01 2474 2405 T5110 T5104
996 Turbo 02 - 05 2474 2405 T5110 T5104
996 GT3 02 - 05 2707 2405 2707RS421 T5104
996 GT3 Super-Cup 02 - 05 2707 2405 2707RS421 T5104
996 GT2 02 - 05 2707 2405 2707RS421 T5104
997 05 - 2405 2406 T5104 T5105
997 S 05 - 2474 2405 T5110 T5104
997 Turbo 06 - 2707 8006
997 GT3 06 - 2707 8006
997 GT3 CUP 05 - 8004 8006
997 GT3 Cup Grand Am Spec. 07 - 8038 8037
997 GT3 RSR 07 - 2488 1674
Boxster [986] 96 - 05 2407 2406 T5106 T5105
Boxster S [986] 99 - 05 2405 2406 T5104 T5105
Boxster [987] 05 - 2407 2406 T5106 T5105
Boxster S [987] 05 - 2405 2406 T5104 T5105
Carrera GT 04 - 2707 2707 2707RS421 2707RS421
Cayenne Turbo (18" wheels) 02 - 2845 2406 t5105
Cayman S 06 - 2405 2406 t5104 t5105
And up to this point, it still does not appear that any of the Pagid sport pads (blues) or race pads (RS-xx: blue, orange, black, gray, yellows) are offered for the 944 n/a.
You are offering to sell a set for $99, Im assuming thats a full set of front and rears, or is that Canadian dollars (retail pricing for a set of front "Pagid OEM's" street pads is under $64 USD)?
Pagid and Textar (and also Mintex) are owned by the same holding company (TMD). So it looks like they are marketing a street compound pad for the 944 n/a calipers, using the Pagid name. Again, I would not consider these for track use.
I hope they’re not the same pad! They charge more for them than the Textars. The material seems to be a different color as well on the Pagids.
PBR apparently makes ceramic pads for the N/A. I supposed those would be better suited for track driving.
