What are original lug nuts made of?
Originally Posted by schwank
OEM are alloy aluminum. For core track use you need to pick up steel lugs.
I just switched to the steel ones. The aluminum ones weigh next to nothing but ive heard many stories of the heads shearing off on them and destroying a wheel has you try to cut it off with a hole saw. The steel ones also have an open hat so you can check thread engagement.
I wanna switch mine to steel - my stock aluminum lugs all look to be a different color. I might as well get stronger steel matching lugs.
Where is the best place to score a full set of steel?
I got mine from Lindsey (because I was buying other stuff from them at the time anyway). I wouldnt hesitate to buy them from any of the big suppliers though (Paragon, Pelican, Lindsey, etc).
Got mine through Paragon, total cost was about $25. The steel lugs are about $1.25 each, the aluminums around $6.
And they look so nice when new also...![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
![](http://img.photobucket.com/albums/v120/TechnoDuck/My%201987%20Porsche%20944/IMG_3885.jpg)
jolly@zoomtown.com
heat treated, zinc-plated, steel lug nuts
$29 shipped
I just got my set in on Saturday and they are excellent quality.
$29 shipped
Originally Posted by Catfood
Your cars are all gonna be slow! Porsche knows where to cut weight to make our cars faster. And when you replace the moon metal with steel it makes me sick!
