WTB: ABS Pump
Hello Everyone, I'm looking for the following part, it's an ABS Pump from a '89 Turbo S.
Anyone have one available. The numbers have to match the ones below because there seems to be a bunch of different models.
![](http://forums.rennlist.com/upload/dscf5692800.jpg)
Originally Posted by xsboost90
saw one on ebay the other day...
Bump, still looking for one, here's some extra information, the exact number I need is this, I think it's different on the 951S because of the bigger brakes so not just any pump will do it seems.
851/200365 95 135 511 301
Hey,
I'm pretty sure the one off my 88 Turbo S will match. I will check in daylight tomorrow and let you know. I owe you for the high quality "How To" on diagnosing a bad ABS sensor so I'll make it easy on you should it be the right one. ;>)
Lanny
Lanny
Dont get hung up on the stamped in number on the pump (851/200365) - thats going to be a date of manufacture and serial number sequence, so you will likely never match that.
The 951 355 113 01 is the Porsche production number (which may be for just a subcomponent, and does not necessarily correspond to the inventory part number for the assembly), the 0 265 200 038 is the Bosch part number.
Also, there is no difference in pumps between the n/a, Turbo, S2, 968, and Turbo S - they all used the same ABS system and components.
