ok- got my dubs on- time to go to the club!
Wow, those look great! Do you think that you will re-spray them? They look good as-is, but may look better color-matched to the color of the 951. IMO.
BTW: in those pics your car looks Black!(or maybe i'm colorblind.)
Originally Posted by xsboost90
or not. Got my wheels fed-ex today and test fit them. The fronts fit perfect w/ a 25mm bolt on spacer. The rears are going to be tricky. The driver's side fits fine w/ a slip on 8mm spacer but the passenger side rubs the inner wheelwell w/ the same spacer. I called up Paragon-products and ordered some 15mm rear spacers w/ longer studs and they should work on both sides-ds is alittle less picky space wise. They look great and the tires are good enough to last me awhile- doubt i'll be spinning the 295 rear tires very much!!!
enjoy.
enjoy.
Are those hollow spokes? What offsets?
I have never seen 11" or 295 work on the rear with stock fenders. I have 10.5 custom built bbs wheels with 285's and still get a little rub. It will be interesting to see how it works.
Originally Posted by hockeydude
What is Dubs? Is it something that you put on your new tires? (tire shine, wax?)
"dubs" is the gansta term for twenty inch rims, now just used for rims in general.
actually i am going to a pca club meeting tonite....
- they are the hollow spokes and it should be interesting to see if they rub. W/ my new spacers they should be in just the right spot and i also have rear coilovers (375lbs) so hopefully it wont rub. I also have 17" cup 2's to stick on there for the track.
- i dont think kevin had these wheels did he? i thought he had some 18" turbo twist wheels....
offsets IIRC are 52 front and 47 rear.
Originally Posted by Dan Shea
I'll cover my ebonics lesson for the day:
I thought that it was some sort of product that Dan (Danno-the-man-o as Vincent would say...) put on his new, awesome rims!
Hey Dan, next time we get together can I try on your shoes? If Kevin did have that wheel on his car with out rubbing I might have to look into getting a set. Although every wheel I photoshop onto my car I end up not liking as much as the cup II's, I just hate that they are a cheap knockoff and are very heavy.
Porsche! why didn't you make a cup II hollow spoke 18" wheel !!!!!!
