Clutch pedal too light
My clutch pedal used to be light but since I've replace the clutch last week its now very light it just does not feel like a sports car should. The shop that did the work tells me this is the way it should be.
Any comment?
Any comment?
Lazer Beam Shooter
My clutch pedal is light in the cabriolet too.
In the 951 it was brutal, solid. For some reason it got really light in the cabrio. Its also stiffer in my girlfriends 951 was well. Go figger?
You can manually adjust the clutch pedal. Remove the fuseboxand and underneath is a spring that you can adjust. I can't remember what size wrench it was. Most likely a 10mm. It's right by the slave cylinder.
Actually bean is talking about the helper spring. It can be adjusted with a 13mm wrench. Loosen the nut to make the pedal effort increase. You can even remove the helper spring if you want a real heavy pedal feel.
____________________________________
1986 944 NA - Guards Red - 91k miles - minty
1983 944 NA - Platinum metallic - 9000 mi beginning a new life
1985.1 944 NA - Guards Red - donor car
1984 911 Carrera Coupe - Guards Red (gone, but not forgotten)
"If you're not living on the edge, you're not living"
Any comment?
Any comment?
Originally Posted by V2Rocket_aka944
Or try to find a nastier clutch.
I've been in the new 997, Boxster and Cayman and those clutches feel like they weigh 5 tons.
Or be cheap and adjust the nut.
