speed and ref sensor
Tearing the car down for the clutch. After all of the talk about the difficulties with the speed and ref sensors causing the housing to catch on removal, I am somewhat cautious. There was talk about aluminum sleeves in the sensor holes (I think). Here is what I've removed and unless they were talking about the aluminum canisters of the sensors, I cannot see anything else down those holes. Is there more?
nope, that's everything.
make sure you didn't move the bracket them mounted in. The bracket is adjustable to allow the set screws in the flywheel to just clear the sensor. Too far out, the sensor might as well not be there, too far in, whammo. There is a procedure on Clark's page to deal with properly setting the clearance.
Originally Posted by tyro
Looks good to me.
If the aluminum portion is missing, you will know it!
Are you doing the bellhousing modification?
What's the bell housing mod? Cut out that section?
Lazer Beam Shooter
You're straight. That Aluminum sleeve thing was a supercession. The original one was superceeded to have an aluminum sleeve. Probally because those sensors kept getting stuck in there and crap
Looks good to me.
Wow....wait a minute, there is an alloy sleeve in one of the bores in that damn bracket. I don't see it there. I have a picture of the bracket in my camera, and I'll post it tonight to show you what happened to me. That alloy sleeve didn't come out with the Reference Sensor...and it hung on the housing and cracked the bracket before I knew what was happening!
-Steve
-Steve
The Sleeve....
Okay...before I get home to post the picture of the Sensor Bracket Carnage incident I pulled up my PET and found the culprit...it's number 31 in the picture:
Steve
Your adventures with the sensor is what got me worried in the first place. I've found the diagram in the pet that you are referring to, but I cannot see anything like that in my 86. (Nice drawing by the way) If I have it then it must be made or 'transparent aluminum'.
Dan,
If you look straight down at the bracket the sleeve is seated in the bore on a lip that sits in a recess on the bracket itself. If you see an extra circle around that bore then you have that darn sleeve. It is REALLY hard to see when you're draped across the engine.
If you can't see it then my advice is to go forward with the disassembly and if the clutch housing comes off easily you're home free. If it binds at all don't take any chances...just take the bracket off. Tonight I re-install the sensors and the new bracket, and the exhaust...then we'll see if I have any parts left over!!
8^)
-Steve
8^)
-Steve
