maybe a silly question: will 951 springs fit early 944?
Originally Posted by sillbeer
Do you know the spring rates on s2? is it same as 951 @ 160?
N/a, S, and Turbo springs are 21.8 N/mm = 124 lb/in.
Turbo S/M030 (87 & later) springs are 28.0 N/mm = 160 lb/in.
Pre-87 M030 suspension is 24.1 N/mm = 138 lb/in
Originally Posted by TheStig
Sillber what is your option code? M030, M031, or M456???
If your car is either an 030, or 031, you cannot use them since these cars have adjustable perches.
Official Bay Area Patriot
Fuse 24 Assassin
Fuse 24 Assassin
You are probably right since I saw an M030 944 suspension with adjustable perches on an '83 about a year ago at a track event. Perhaps the guy bought a set of used ones from a later car?
