Clutch job, w/o removing transaxle
Hey Man
Originally Posted by PorscheDoc
A clutch job on an NA is a 4 hour job, doing it properly. Why the hell would you cut a hole in your car to try and do it any quicker?
Originally Posted by KuHL 951
How much 'marching powder' does it take to do this in 4 hours? Show me the secret Obi Won.
Lol, I'll be glad to school anyone in the secrets of a clutch job I think people screw around alot when they are supposidly "working" on cars, lol.
Originally Posted by dme
Seriously though, I'm sure after you have done a few it gets much easier like most jobs on these cars.
My indy mechanic did the clutch job in 8 hours, plus another billable hour due to sending the flywheel out for resurfacing.
He unbolted the entire drivetrain aft of the bell housing as a unit, and rolled it out of the way on the rear wheels.
If I had this to do again, I'd use that procedure myself and do it in my garage. Also, I'd 1.) get one of Marcus Blazzak's clutch forks, which are cheaper and much better than stock, and; 2.) clean, drain and refill the transmission while it's off the car, being more accessible then. This would be a good time to repack the CV joints, too.
Originally Posted by Oddjob
...and add a 4 wheel alignment to the labor bill because the rear suspension was R&R'd.
Sears charges $90 for 4 wheel alignment on their computerized laser machine. However, I've done my own alignment using yellow thread and a 1/16" allen wrench, plus a spirit level for the camber, in just a few minutes. Car tracks straight ahead, hands off, at 110mph. This is not a big deal. After I did this, took it to laser alignment shop as a cross-check, and they refused to charge me because their laser showed the thread trick to be as accurate as their machine.
what did you use the allen wrench for?
Originally Posted by MPD47
The axles are the worst part of taking the transaxle out. After that it's another 6 bolts or so and it's out, less than 30 minutes. I dont see the point.
It's amazing how quickly people who need to use my garage and tools disappear when it's time to do a clutch...
An experienced mechanic should be able to complete a clutch job on a 944 n/a in 4-5 hours, and 8-9 on a turbo. To remove the whole transmission takes under an hour, maybe a little bit more for cars equiped with an oil cooler (slightly more difficult access to the axle bolts).
Definately helps if you have access to a lift.
Hey Man
Originally Posted by Scuba Steve
...It's amazing how quickly people who need to use my garage and tools disappear when it's time to do a clutch...
unless you weld whatever you cut off back this probably isn't suck a good idea. like someone already mentioned exhaust fumes getting into the cabin is a comon problem with the 944 already.
Most accurate quote I've seen all week. I feel the same way about wrenching parties, one or two people do all the work and their own cars don't get finished.
Under the Radar
Official Bay Area Patriot
Fuse 24 Assassin
Fuse 24 Assassin
A crack addict with a WSM takes 4 hours on a 944, but don't ask him if he torqued all the bolts up or installed a replacement pilot bearing
