Battery quick disconnect system - anyone use it?
Considering the frequency that I (and I assume many of you) disconnect the battery to perform various maintenance duties on the car, I am considering a tool-less method of removing the battery cables from the battery itself.
I know some race cars use these quick disconnects, and was wondering if anyone here has installed these on their car? It seems like a slick way to disconnect the battery cables without having to grab a wrench. You simply pull the connectors apart -- done.
These are 4AWG (each), what does that mean?
Resistance is Futile
Forgive me, but this will provide you with all your inquiry on AWG!
http://en.wikipedia.org/wiki/American_wire_gauge
My friends use marine grade circuit breakers put inline with the positive battery cable.
http://www.westmarine.com/webapp/wcs...allpartial/0/0
All you need to do is press the red button and it opens the connection. They are available in 50-150amp ranges. I really dont know if these are the best solution, but they work well for those who i know that use them.
http://www.westmarine.com/webapp/wc...hallpartial/0/0
Originally Posted by icat
I've got a $4 battery disconect from Wal-Mart on my 951. You can find them in the battery department. All you do is spin a *** and the power is cut.
