Bad MAF?
Bad MAF?
So I drove to chicago yesterday (300 miles roundtrip) and my car was doing great the entire time up until about 10 minutes from my house. Whenever I would step on the gas more than about halfway it would bog for a second or two and then go. I thought maybe the car had just been running for a while and maybe it would be better in the morning. I drove it today and it has gotten even worse. Now if you push it down more than about 5% of the way it will completely bog and won't even start going after a few seconds. You can push the pedal to the floor and it will do nothing. While idleing I unplugged the MAF and it didn't seem to make much of a difference and the car still wouldn't rev. So I'm starting to think that it's a bad MAF...Anyone ever have similar problems??
My car is an 87 924S.
Thanks!
Thanks!
If you can get to speed and higher rpm slowly I would check the fuel filter. Look for vac leaks first though if it won't rev at all. My 86 had the same problem except I could nurse it to speed and cruise, and heavy foot resulted in the bogging no matter what speed I was going. It was probably from a low bulk tank at the gas station sucking up sediments.
Where is the fuel filter? Thanks!
Originally Posted by alxdgr8
Anyways to test the filter before I go and buy a new one? Also, there are two listed, one comes with fittings, the other doesn't..which should I get? Thanks!
http://www.pelicanparts.com/catalog/..._pg1.htm#item0
Thanks, I just ordered it, should be here wednesday. Hopefully that'll be my problem.
You should still look for vac leaks while waiting for the filter. You realize there is also an inlet filter right at the tank? This one is supposed to catch larger sediment and usually won't clog up on a plastic tank. Does the 944S have the steel tank like the early cars? If so you might have a big load of rust that forms from condensation on the inner roof of the tank and falls onto the bottom as small plates.
