Fixing broken vacuum hose
I am trying to fix the black vacuum hose that runs near the intake manifold towards the back of the engine. The piece connects to what seems to be a y-shaped connection, which is attached to one of the bolts going to the intake manifold.
I've attached a pic as reference. Is there a special way to remove the bolt in the blue box?
Thanks.
PS. I'm not sure who's engine this is...but thanks for the clean photo
Thanks.
Should be 17mm. Don't force it to much though; the bolts are apparently somewhat easy to rip out of the intake manifold, and you have to glue them back in place if you break it out. I just took mine off after who knows how long without any issues, so it shouldn't be anything troublesome.
