What would cause a clunking noise in front pass. wheel well?
Set to Full-Auto
Car is an early N/A, here are the symptoms:
The noise is an intermittant clunking similiar to a failing CV joint
It is definatly coming from the front right wheel area
Sound ONLY happens with car in motion at sub-5mph speeds
Applying brakes will put an immediate stop to it
Sound will happen turning or going strait
Here's what we have done thus far:
Installed new front wheel bearings
Made sure brake calipers were firmly attached
Balljoints are brand new
Control arm bushings front/rear are brand new
Swaybar bushings are new
This is driving us nuts - anyone have any clues?
Set to Full-Auto
Packed well with Mobile 28
Races are not new, but looked/felt good - not pitted or anything.
Noise did not change AT ALL when I changed the bearings.
This is kinda odd. My car had some clunking up front like yours but only when turning and going slow. I had been working on the front spoiler and didn't put back in all the bolts or the metal support. Everything was clear when parked and it didn't make a noise when at speed. When I put all the bolts back and the supports the clunking seemed to shortly go away. I never did figure out what was clunking (it was not rubbing) and I am not sure if what I did fixed it or if it just magically went away.
Have you checked all suspension bushings in A-arm, and that all bolts are tightened well, especially the two bolts and nuts that attach the bottom of the strut to the spindle. I know on the cars with adjustable shocks the ecentric bolt that adjusts camber on the bottom of the strut can come loose and make a clunking sound as it moves back and forth a 1/2" or so. What about the 4 crossmember bolts? I have had one od those back out on me. Locktight is my friend now!
Not sure if this helps or not, but my car made a clunking noise and found out that both my front shocks were bad. I could lift the car up and it'd stay up, or push it down and it'd stay down. Had my own ride height kit
Set to Full-Auto
Sway bushings are brand new as are all the shocks and the top strut mounts. I am leaning towards loose strut hardware, I'' be sure to post my findings.......
