Fresh air fan works intermittenly.
I could use a few suggestions as to where to look. I am pretty deficient it all areas, but especially with wiring. So, please bear with me.
Definitely a short somewhere. When the fresh fan works, all positions work just fine. AC fan works flawlessly. Replaced switch and fuse. Unless I am missing something, I don't see a fresh air fan relay in my user manual.
What should I check next? Thanks in advance. Michael (83)
The '83 electrical diagram shows a 4-pin fresh air blower relay. Not sure where it's located though. What you could is pull each of the 4-pin relays until your blower stops working permanently.
BTW the Haynes manual has an '83 electrical diagram in the back. It''s cheap.
Got one. I'll check it out. Thanks. Michael
