Trying to remove door side rub strip
Old 02-25-2007, 09:56 AM
shiners780
shiners780's Avatar
Originally Posted by wizkid918
anywhere that sells automotive paint should have it
just ask for a 3m eraser wheel, its already molded onto an arbor, mine was a skin toned color, and about 3 inches in diameter. i got it at Finishmaster
Cool, thanks, I'll go hunt one down.
Old 02-25-2007, 08:54 PM
BlueRiver86
BlueRiver86's Avatar
Acetone can damage clearcoat if it stays in contact too long. Be careful and you should be fine with it. As with any solvent, use as small an amount possible to get the job done.
Old 02-26-2007, 12:06 AM
35thSLP
35thSLP's Avatar
you can remove it with a hair dryer and a piece of dental floss. heat up the strip as best you can without burning the paint then use the floss to essentially cut the molding off the car kinda like a cheese cutter. the floss won't hurt your paint and it will leave minimal residue on the body.
Quick Reply: Trying to remove door side rub strip
