Wiper delete plug
I've been looking for a wiper delete plug but have not been able to fine one at all! Can any of ya'll point me in the right direction?
Thanks, Ben
Thanks, Ben
Check the Mcmaster Carr catalog for "plugs"...i got one for $1.95 and it fits perfectly....It will not pass as a factory part, but it definitely does the trick.
$30 sounds a bit steep to me, but I would have suggested Sunset. I got mine from a wrecked 944 for free... The Home Depot idea also sounds ok, actually... Also, the Scirocco idea is cool too- I'm on a mission now, to find a deeper cig lighter- the female part- radar detectors slip out- was thinking that some Audi or VW part might fit... It's cool finding little things like that that double on VWs...
Hot tip: If you have a parts car or have removed/are removing the interior of an 85.5/86, the plastic plug on the C piller that fills the rear shoulder harness mounting bolt hole is a perfect fit in the hole left by the wiper motor armature. Just source a nut from your nuts-n-bolts tray and you're in business.
