No horn
since my turn signals didn't cancel anymore I thought it was the canceling ring. Replaced that but now the horn doesn't work. Is there a seperate relay or fuse for the horn? I can't find it. What is even worse the canceling ring didn't fix the original problem!
Thanks as always!
Have a safe and happy holidays all!
Thanks as always!
Official Rennlist
Borat Impersonator
Borat Impersonator
Did the horn work before? If the horn worked fine, then you replaced the canceling ring or whatever and now it doesn't work, then thats the problem.
if it never worked, the horn relay is on the bottom row of relays, third from the left. It's the one with a 16a fuse on the back of the relay.
Official Rennlist
Borat Impersonator
Borat Impersonator
i don't know about the canceling ring and how it relates to the horn, but you should double check the ground wire that connects to the wheel and then move on to the relay, etc.
Official Rennlist
Borat Impersonator
Borat Impersonator
If the canceling ring didnt fix the original problem, try swapping the old one back in, and then see if the horn works.
