VERY DIM lights, no start when less then 35 degrees
Friends N/A just started to do this. At first all lights are OK then after about 15 min everything gets very very dim (headlights become useless) and the car feels like the battery is about to run out. The engine sounds like its hardly firing and rpms go to ~600rpm. Tach needle goes all over the place.
Battery light does not come on, car will run as long as you want but when it is cold does not start. A slight jump will get it started right away.
The 2 8/10 gauge wires coming off of the positive lead are cracked up. I'm going to repair that today..does that sound like the problem or do you guys have any other ideas? I was also going to check out the grounds
thanks
Mike
thanks
Mike
You could take it to one of the big chain auto stores that tests batteries and alternators for free. No doubt those wires are at least part of the problem, but if the syptoms started suddenly it would make sense that something else went bad; wires get progressively worse over time, not all of a sudden. My money is on the alternator.
i just got the 700CCA international battery from advance auto parts. my car started fine with the old one, i replaced it to be on the safe side.
when i turned in the old battery i had them test it. it was putting out 400cca.
You may want to try the civic battery. probably has polarity the other way and less CCA, but you will possibly save $5. Well worth the two hours to make it fit.
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
He brought it over and I found quite a few shoddy bits of wiring some PO did (and it wasn't me..wiring looked old) repaired what I could.
The other day I let him borrow a spare battery of mine and same thing happened... We are going to pick up the proper wire to replace the leads off of the positive terminal. I'll check the alternator too.
thanks guys
mike
thanks guys
mike
