kyb shock adujustable lowering rear end
wondering if i buy the kyb shock will i be able to lower my rear end as it sits a little to high now
if not what should i do
shocks wont effect the height of the rear end- you have to adjust the accentric bolts on the rear axel itself. Do a search on this- there are two large bolts at the front of the arm, loosen, car drops, tighten...easy as that.
while shocks dont affect ride height
ride height affects shocks, KYB's in general are not a shock to use for lowering purposes, they dont like it, will underperform, and deteriorate at a much faster pace than otherwise.
