Newbie.. need help.. with 944
Old 12-06-2006, 11:42 AM
Phi1720
Phi1720's Avatar
Originally Posted by elite001
How can I get the correct wiring harness? so if I buy the unit.. I will have to buy the wires also? if I take it to the shop.. I thought they already provide the wirings?
Any shop will have wiring harnesses in stock. They are usually $15 or so. Its basically an adapter that connects the wires coming from the back of the cd player to the correct style of connector in the dash of your car.
Old 12-06-2006, 11:55 AM
elite001
elite001's Avatar
Originally Posted by chrly924s
The Alpine SPS-460A speakers are a perfect fit and sound great for the money. They are shallow enough to clear the window mechanism and use the factory grills.
what is these speakers for? fronts at both doors one or, rear one?
Old 12-06-2006, 12:10 PM
Sythik
Sythik's Avatar
http://www.crutchfield.com/S-LmGlMz0...00&I=120701822
This is what I used to install my radio just get a couple butt connectors and crimp the harness that goes into the back of your radio to this harness and then plug it into the harness in the car. Its very easy to do. Most audio shops wont have this instock because of the age of the car and what not.
Old 12-06-2006, 12:13 PM
Hoss Ghoul
Hoss Ghoul's Avatar
Example of Ipod ready Alpine Head Unit
http://cgi.ebay.com/New-Alpine-CDA-9...QQcmdZViewItem
Two examples of adaptors needed to connect Ipod to an Alpine Head Unit, one with charging capability:
http://cgi.ebay.com/NEW-ALPINE-iPOD-...QQcmdZViewItem
http://cgi.ebay.com/alpine-aux-input...QQcmdZViewItem
I'll get you the model# for the JBL's I have and snap some pictures of the rear box/head unit a bit later today. The Alpine speakers for the doors suggested above may be a better option, and more likely to be available.
Old 12-06-2006, 12:27 PM
elite001
elite001's Avatar
so is this means, if I buy this, I will be able to connect this unit or all of those stereos listed by Hoss to my 944 1985 car? please give me some confirmation and I will buy this thing from crutchfield right now...
I cant wait no more...
thanks guys.. thanks alot for the input.. I am so happy that I found this forum... thank you so much
and again.. forgive me for my stupidity as newbie and I hope you guys won't get pissed for me asking so much lol..
Old 12-06-2006, 12:52 PM
elite001
elite001's Avatar
Originally Posted by El Commandante
If your car has the factory fader switch,(the thing below the radio on the center console with a speaker icon) it will allow all of the 4x6 speakers front and rear to be run through the front output on the head unit.
That leaves the rear output for a good pair of 6x9s in the hatch. Good 6x9s DO NOT disappoint!!!
I am really not sure what you mean
but you can see my car's interior's where you can see there is no stereo there.. maybe you can tell me a little bit more clearly in the picture and see if my car has it or not..
thanks
Old 12-06-2006, 01:06 PM
Tom R.
Tom R.'s Avatar
Your car is a 85.5 or 85 1/2. The dash was changed mid 85. if you search on the web for stuff either call it a 85.5 or 86. There were a lot of changes made for the 85.5. mainly to the interior.
Old 12-06-2006, 01:07 PM
Tom R.
Tom R.'s Avatar
where are you located?
Old 12-06-2006, 01:11 PM
elite001
elite001's Avatar
I am located in columbus, OH
what about you?
and what does it mean by it's 85.5 is it a more worst car? or something?
so when I'm looking for harness in crutchfield there isn't any option for 85.5 should I go for 86? or 85?
thanks
Old 12-06-2006, 01:58 PM
Tom R.
Tom R.'s Avatar
Go for 86. All interior in your car would be 86 instead of 85. I think but am not sure that everything in your car would be 86 instead of 85 if given the choice.
Old 12-06-2006, 02:18 PM
alordofchaos
alordofchaos's Avatar
No, having an automatic makes it a worse car Sorry, just funnin' ya! Welcome to Rennlist! Just don't ask if the timing belt is at the rear of the engine...
Many people consider it better - especially the AC/heat. Do a search; there are basically two interriors - early and late. Late is 85.5 and older; late has a rounded oval dash vs square dash. Dash cracks come with both a search will get you pictures of the older dash.
Late also gets the 6-digit odometer (you'll see lots of older cars claming low miles, when the 5-digit odometer rolled over) and two speakers in the door (early had, iirc, just one on the dash or something weird like that - at least that's what I remember from my 924)
You live in a good spot - there are several local listers who can help you out of a tight spot.
EDIT: I don't see the fader switch, but it might be behind your shifter in the picture. It would be in one of the spots to the right of your switches for the outside mirrors, sunroof, and rear wiper.
Old 12-06-2006, 02:19 PM
heltonjk
heltonjk's Avatar
I just installed an Alpine head unit with the ipod adapter in my 87. it was a breeze. You just pull the old one out, plug the harness you should get into it, and slide the new one in, basically. I drilled a hole in the little bin underneath to thread the ipod cable through, so my ipod just stays in the little cubby. No one sees it if I wanna just leave it in my car. works well for me. By the way, this is my first post. hope it was helpful.
Old 12-06-2006, 02:22 PM
heltonjk
heltonjk's Avatar
I just realized you posted you were in Columbus. So am I...I could probably help you out. I'm no professional stereo installer, but I've swapped a few head units.
Old 12-06-2006, 02:23 PM
elite001
elite001's Avatar
yea I know.. the shift stick look kinda ugly too.. any suggestion what can I do with that...
thanks so much
Old 12-06-2006, 02:24 PM
alordofchaos
heltonjk, first post and you're already a paid member!
And yet another rennlister in Columbus, OH
I'm pretty sure that's where my car came from (the seller drove it up to Dearborn for me)
Quick Reply: Newbie.. need help.. with 944
