Engine for a 937 replica
I have a 924s I plan to turn into a 937 ('81 carrera gt) replica someday.
I would like to give my car the power it will deserve. So how do I add a turbo charger to a non turbocharged 2.5l. I won't be doing it till after it is a good replica.
This isn't really a "how do I turbo my na" thread but I expect flames any ways.
Here's what I have so far
turbo intake on a NA head
turbo exaust manifold on an NA head
turbo, turbo (duh)
turbo intercooler (Maybe lindsey stage V)
adjustable wastegate (MUST HAVE to limit boost 2-6 psi)
mainfold to tip exaust (sucks cause I'm about to buy a new NA one this week)
piping
From what I understand the above parts WILL bolt up to the NA block.
For fuel it seems like new options are opening up and I'll just pick the best...
1)MaxTronic
2)tec3
3)ms
4)wolf3d ems
:note: I have noticed that lindsey version of the wolf 3d ems is a full version old and now unsupported my wolf ems. So I would buy a new unit straight from them which would acually be cheaper $1,800. However, if the lindsey version can read the inputs from the speed and refence sensors then... Does the new wolf unit do the same. If so move it to the #1 spot on my list.
or worst case scenario would be to use the FQS to scale the map and retard the ignition
I'm getting sleepy now but want to get my plan "approved" by the guys here who know what works and what doesn't.
turbo, turbo (duh)
piping
1)MaxTronic
2)tec3
3)ms
4)wolf3d ems
Official Rennlist
Borat Impersonator
Borat Impersonator
no offense, but how is this not a "how do I turbo my n/a thread?"
You have an N/A 2.5 liter essentially 944 engine, and you want to add a turbo.
If you want 937 replica, then you have to have a turbocharged 2.0 under the hood.
As for engine management?
For app. 1000$ you could get VEMS Genboard v3.3 that supports Porsche 944 crank trigger setup and all other stock sensors and it will do all types of ignition straight out of the box (including COP, CDI and even IonSense if you have proper hardware).
It has built-in dual WBo2, EGT and knock support.
Official Rennlist
Borat Impersonator
Borat Impersonator
you know, I have wondered for a while why people say you can't turbo an N/A car because you need a stronger drivetrain to handle the power, but what drivetrain did they use on the Carrera GT/S/R? Wasn't it just the a modified 931 drivetrain?
Why not save yourself some trouble and drop in a 951 motor and tranny complete? It would be a lot easier than rebuilding your motor than having to worry about the tranny handling the extra power.
Here is a thread about slapping a turbo on
https://rennlist.com/forums/showthre...rera+gt+tranny
one about the gts/r tranny
and if you decide to do it.....BRAKES!
944 trans + additional HP = steel granola.
The CGT had an '80 931 trans - a snailshell type.
The CGTS I believe also had pretty much the same.
The CGTR had a derivitive of the above, snailshell type, with a nice big fat diff, either straight from or derivative of the 917 diff. It's pretty large.
As for what you're looking to do - why wouldn't you just swap in a 951 drivetrain??? Though yes, a 2.0L Turbo would be "correct" a 2.5L T would give better return for the same or less effort. Easier to do aftermarket EFI/engine management on!!!
I still don't see how this isn't a "how do I turbo my NA?" thread.
Agreed... The Snailshell is notably tougher but I don't foresee any problems with a gently treated 944 trans. You have to be smart about your driving and avoid things that could seriously damage your drivetrain. This said a transmission swap would occur just perhaps not immediatly.
This isn't a turbo my na thread because right off the bat "sell and buy a turbo" is not an option.
the regular 937 motor was a fair bit more than a 931 motor. Many of the parts to create are expensive or hard to find. Not mention the value of the experience I already have with the 2.5. however a direct swap of the 968 3.0 with Variocam would definatly float my boat. even more if I can link it to a standalone and run COP.
as for the straight 2.5t swap, I would like to keep my low end power and fear that motor while easily having better topend might not be as much fun in the lower. I'm just looking for a little extra on the top, for passing and the fun moments.
and ooooh the vems how could I forget. are yousure it supports COP as that would a nice selling point. mmmm dual WB02. MS, as cheap as it is, is falling on my list as router board release has come and gone without product the last time I cheaked. It seems like the development priorites have shifted to the GIO board or whatever they call it.
Thanks for the links ahead of time as I haven't looked at them yet. but I'm sure one of them is probably the guy who did it. which is awesome as I lost the bookmark.
probs to that guy.
lt1+aluminum heads disquaifies the car from club racing in the future.
probs to that guy.
I really am reluctant to put much more than the intended HP thru that N/A trans. Just my 2cents here.
Originally Posted by tifosiman
Once it blows up, its only worth its weight in scrap, at best.
Not a very good return on investment IMO.
Just because you don't forsee any problems doesn't mean there won't be any.
I don't see how "sell it and buy a turbo" isn't an option. Perhaps you need to better explain your goals/motivations.
But you say you want low-end torque - then 3.0L definitely makes far more sense than 2.0L turbo setup, be it 931 or 937!!
I'm certainly familiar enough with a CGT motor; a friend around the corner has both a CGT and a GTR. I've seen all the bits; you could even build a GTR motor out of a 931 motor, if you're good enough at fabricating. The vast majority of the GT and GTS parts, not to mention 933 and some GTR, were made from modified stock parts. The GT, just bump the compression, boost, similar things, easy enough to get equivalent performance or better, especially if you're not bent out of shape about making it factory-original.
Bottom line, define exactly what you're trying to make with respect to styling and performance, we can give much better direction about how to get there from where you are...
