Coolant system leak additives
Do any of them work without ruining the cooling system? Barrs? SEAL-UP?This is for a non porsche applicatin.I have a leaking intake manifold gasket on a gmc 5.7 lt engine.
Barrs worked pretty well on my volvo's radiator and it hasnt blown uip or started overheating yet. thats all I can really tell ya. if it's a gmc itll prob be worth a try. just be aware that it will look like you have milkshake coolant until you flush it. It doesnt say you need to flush though. I believe seal up and some others you do need to flush the coolant afterwards.
I had MASSIVE problems on my old Z-car where the PO used some of that stuff to fix a radiator coolant leak. It clogged up the heater core and thermostat. Many of late hours were spent cursing that stuff.
If you do use it, just be sure to follow all of the directions. Or you could just replace whatever is leaky
Be careful with any sealants that have bentonite (fine clay) in them. They can really clog a radiator and the bad part is it doesn't fail until your engine gets real hot in the Summer. I had a Maxima the dealer had installed some in before I bought the car. No problems in the Spring until the car got hotter than usual and then the stuff loosened up all settled in the bottom half of the radiator core. The dealer had to replace the radiator and heater core because the clay baked on so hard they couldn't flush it out to clean it.
