Fire Extinguisher Mount with Sparco Seats completed
Well I started looking around for a Fire Extinguisher Mount to place my Fire Extinguisher in front of the passenger seat and I could not find anything commercially available. I have Brey Krause mount for side mount Sparcos but it would not fit under the bottom mount of the Torinos. So I made my own out of sheet of aluminum. Simple enough but I am now thinking it might look better to have skeletonized with holes? Anyway here it is.
IPSC
![](http://img.photobucket.com/albums/v207/IPSC_GUY/FireExtingisherMount006.jpg)
![](http://img.photobucket.com/albums/v207/IPSC_GUY/FireExtingisherMount003.jpg)
IPSC
![](http://img.photobucket.com/albums/v207/IPSC_GUY/FireExtingisherMount001.jpg)
That looks nice. Holes along the bolster side would look neat and would balance the offset of the extinguisher. Nice job!
Strike that. No one will see the side under the bolster. It was just that one angle.
which seats are those? how do they fit and what size waist are you? im looking. with a measly 33" waist i thought the recaro srd was a little tight around my back.
IPSC
did you try the sienas? there is no place by me to try seats. i sat in a SRD at an autocross and liked it but thought it was tight in the back/chest area.
there is a set of brand new sienas on ebay with a start of 500 and no bids. tempted if it is just a different kind of foam.
You may have seen this but I thought i would post it anyway. I have no way of butt testing these either.
Seat Dimension Guide
Location: San Francisco, CA Porsche: '92 968 Blk/Cashmere
There is a potential problem with the way you mounted it. AL fatigues and develops stress cracks very easily when compared to steel. They way you have the sheet mounted, there is nothing supporting the front and it's acting like a lever on the mounting bolts. As the car goes over bumps and the weight of the extinguisher flexes the AL sheet, it will eventually crack where the bolts are mounted. The only question is how long will it take to a develop a stress riser and begin the development of a crack.
Be sure to keep a close eye on it for cracks! Other than that, it looks good
Be sure to keep a close eye on it for cracks! Other than that, it looks good![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
IPSC
