Best way to cut two oval holes in nosepanel?
Have it both ways
Hey Dan-
Vented nose and filter in fender. I haven't been on the archives, but enough knowledgeable folks told me not to nose it.
Besides the fact that I haven't detailed my car since paint (bondo dust) and overspray on mushroom filter (will change out), I think you'll get the idea.
Either way, can't wait to see your handy work.
mj
mj
Well now I'm curious - what are the negative effects of venting a 951 nose panel? I presume it is pointless to vent a 944 nose panel except for more radiator cooling.
You should find someone to roll the edges out on the holes, otherwise you are going to have a stress concentration. Any real factory race car with holes in panels, you will see that they roll the edge. It is not just for looks.
My car has a 931 vented nose and i see noticably cooler temps when running at highway speeds, probably close to 10 degrees cooler than i used to get (this reading off my VDO gauge tapped into the upper radiator hose).
Another interesting note.. i have popped the hood after long drives and the airbox is COOL to the touch. Something to consider i guess with the placement of a larger air filter debate.
Set to Full-Auto
I'm going to be honest - I'm mainly doing it because I like the way it looks. Putting the airbox there does two things for me.
1. Gets it out of the way - thing takes alot of room under there, make it easier to work on without it.
2. Gives me some kind of valid reason to vent the panel.
