extremely technical question:
Originally Posted by M Danger
can the porsche mug with the gold trim, be used in the microwave?
After you are done be certain to write up a DIY article and submit it to the DIY section.
Then, you should probably find some vendor that isn't a sponsor here on Rennlist to quote you a good price on those mugs, and arrange a group buy.
Originally Posted by Phi1720
It should work as long as you aren't trying to swap expresso into a decaf framed, early-offset mug.
just buy a tur-- i mean, coffee maker
Cast Iron Man
Originally Posted by Catfood
How do you become a member of rennlist?? I only have like 8 posts as of now, but I love my 944 to death and would love to be part of this community
Resistance is Futile
What!? Did the requirements ease up or something? I had to take a test:
1. Name and locate all the ground points.
2. Memorize the vaccuum diagram and then remove/replace all lines blindfolded.
3. Recite and demonstrate the tightening sequence and multi-stage torque values for the head.
4. Manually calculate the reindex settings after a 1" drop/200# spring replacement.
5. From a random selection of locations, identify the appropriate size bolt/pitch/grade of the location.
So how is it that the standards are set lower?
hehe.
hehe.
