Engine removal.
Old 10-30-2006, 11:04 AM
NeoRules
NeoRules's Avatar
Default Engine removal.
Ok.. I got to pull three seperate engines. LONG STORY...
Anyway two are in driveways and one is in a garage.
Looking for pros and cons of pulling out the top vs bottom.
I have searched threads but I really would like to hear from people who have actually done both!
Two of the cars are manual 83's and one car is an auto 88.
P.s. One of the engines already has the head removed it that makes a huge difference. I could put it back on just to pull the darn thing..
Thanks so much in advance...
JC
Old 10-30-2006, 11:15 AM
tinman944
tinman944's Avatar
I have done it both ways.To tell you the truth out the botom has always worked the best for me. there is much more room for the engine to come forward if you go down instead of up.
Old 10-30-2006, 11:38 AM
KuHL 951
Hey Man
KuHL 951's Avatar
I have to do this twice also. I have a hoist so will probably drop out the bottom. If you go out through the top do you need to pull both the radiator and AC condensor to get enough clearance? Does a pull out the top require that the bellhousing/PP/ be removed first also? Just being able to leave that on the engine would get my vote for a bottom drop.
Old 10-30-2006, 11:46 AM
spazegun2213
spazegun2213's Avatar
out the top is no fun. Even with a bare engine you have to tilt it and move it and tilt it again, etc. I did this on the parts car and with nothing in the bay but the engine, its not to bad, but if this was done on a running car, i think out the bottom would be better.
Old 10-30-2006, 12:15 PM
M758
M758's Avatar
Done it 3 times out the bottom once out the top. I will always do it out the bottom as it is easier.
Old 10-30-2006, 01:03 PM
500's Avatar
I've only done it out the bottom, but it was my first engine removal and I found it very easy FWIW.
Old 10-30-2006, 01:09 PM
StoogeMoe
StoogeMoe's Avatar
I've done it both ways, I too give my vote for the bottom. I was worried that I'd have to jack the car way up in the air to make clearance, but I was able to do it with normal jack stands.
____________________________________
1986 944 NA - Guards Red - 91k miles - minty
1983 944 NA - Platinum metallic - 5000 mi beginning a new life
1985.1 944 NA - Guards Red - donor car
1984 911 Carrera Coupe - Guards Red (gone, but not forgotten)
"If you're not living on the edge, you're not living"
Old 10-30-2006, 01:13 PM
Rock
Lazer Beam Shooter
Rock's Avatar
Bottom bottom bottom. If you need help dude hit my digits up. The last VA car I fixed was in F-burg, which happens to be the girlies.
Old 10-30-2006, 02:09 PM
tinman944
tinman944's Avatar
even if you take the a/c and radiator out the crank pulleys hit the back of the nose panel.
Old 10-30-2006, 02:34 PM
PeteL
Got Nothin'
PeteL's Avatar
I have pulled one, out the bottom worked great.
Old 10-30-2006, 02:51 PM
tinman944
tinman944's Avatar
Hey... out the bottom is the answer
Old 10-30-2006, 03:02 PM
Jakerx
Hitsquad Ninja
Jakerx's Avatar
Out the bottom is the way to go bud. Good luck.
Old 10-30-2006, 03:03 PM
spazegun2213
nah, you just have to caress it a little, tell it will be ok, and then tilt her ever so gently and RIP HER OUT! lol
Old 10-30-2006, 03:48 PM
NeoRules
NeoRules's Avatar
I guess I need to get some jack stands....
Old 10-30-2006, 04:13 PM
spazegun2213
harbor freight.... I've learned to love that place
Quick Reply: Engine removal.
