Water in passenger side trunk
I am getting an accumulation of water in the passenger side hole in the trunk. I cleaned the drains on the wing...where else could water be getting in from (gas cap?) Also, should there be some sort of hole to drain water accumulation that stays there?
It's ironic that you posted this tonight as I just found the same thing this afternoon on both driver and passenger side. Earlier, I'd noticed my hatch key seal was missing and some water was getting in through there. Also, when I replaced my hatch seal, I saw a huge difference in coverage sonce the old one was "shriveled." I think both of those things allowed water to get in as I pulled the carpet away from the back of the trunk area and saw a small amt. there. It was just by chance that I noticed the "pools" tonight.
After some digging around for awhile, I found a drain hole on each side. They were stuffed with some kind of rubbery stuff (almost like what people use in dorm rooms to hang posters). When I removed it, I saw the small hole on each side and pushed the debris away a little and eventually all the water went away.
Originally Posted by mavfan
the hatch seal? and yes there should be a couple holes where a tube from the sunroof and hatch latches
