Cooling system questions
#31
Anyone state side have a place that sells the 8mm grease fitting? Ive checked a Pepboys and a Autobarn. The only metric sizes they carry are a 10pk of 6mm and 10mm fittings. Going to try Walmart and the Autozone by me also. Just wondering if anyone knows of any national chains that defenetley have it before i go all over the area looking for one.
#32
Rest In Peace Jaak
Cable Guy
Cable Guy
Canadian Tire does .... but the drive is a bitch .....
Funny when you try to find something you see everyday and not be able to buy one when you need it.
#33
Well i looked around for the past hour or so online and got the idea to use the bleed screw on the Brembo Calipers as it looked the same size. I looked it up and the Brembo is M10x1.0. So i got the bright idea of cross referencing bleeder screw sizes..thanks to the sizes on the SpeedBleeder website i was able to figure out the 90-97 Mazda Miata, 93-95 RX7 and some year Maza MPV's use a M8x1.0 bleed screw for the front calipers.
It took me a while to find it, but i eventually found the Mazda version of PET...and found the part number for the bleed screw...
B001-33-691 Cost seems to be less than $6.
Going to check the Mazda dealer tomorrow to see if they stock it.
If not ill just continue the search for a 8mm grease fitting.
