Another problem. Marker lights not working
for some reason all of my marker lights on the 85.5 are out. They WERE working before I "fixed" the car.
The headlights work fine, both low and high beams. also the reverse lights work fine. I did think it was remarkable how all the lights worked on the car before I fixed it.
What did I do?
What did I do?
I swapped out front ends, body panels only, I left the engine and susp. alone. I did the oil cooler seals and the only electrical stuff done was install a new battery, reconnnect the fogs/turnsignals and hook up a radio.
